A lot of "semantic error" reported by the IDE of the example code
Search instead for
alex_yu1
hello,
   when i import the example of the SDK, there are a lot of "semantic error" reported by the  IDE . could you please help to check this issue. i already had  installed the S32DS_PA_v2017.R1_UP7.zip
thanks and regards
qingzhou
alex_yu1
hello Rares
    i try to rebuild the index as your guide, but it do not work.
raresvasile
thanks and regards
qingzhou
raresvasile
Can you try to rebuild the indexer (Project > C/C++ Indexer > Rebuild)?
Let me know if it worked.
Rares
