A link for downloading S32DS for power architecture as .exe file not zip file
已解决
跳至解决方案
3,620 次查看
Ahmed_Abd_El-Hafez
Hello NXP team,
Can you please give me a direct link to download the S32DS for Power Architecture as .EXE file not zip file . I searched but didn't find
thanks in advance.
1 解答
3,604 次查看
lukaszadrapa
Hi @Ahmed_Abd_El-Hafez
just click on this link:
https://www.nxp.com/webapp/swlicensing/sso/downloadSoftware.sp?catid=S32DS-PA
and you will find the exe file here:
Lukas
在原帖中查看解决方案
6 回复数
3,547 次查看
Ahmed_Abd_El-Hafez
I tried on another computer and it worked.
Thank you very much
3,605 次查看
lukaszadrapa
Lukas
3,594 次查看
Ahmed_Abd_El-Hafez
I downloaded and installed it but when I run it it gives this although S32DS for S32 platform is run on my device
3,579 次查看
Ahmed_Abd_El-Hafez
I think this is because it is for win32 only not 64 (however it must be supported by both win32 and win64)? Is there another one for win64?
3,553 次查看
lukaszadrapa
Both 32bit and 64bit systems are supported. You can find in the installation guide:
I reinstalled this version of S32DS short time ago and there's no problem with the installation package.
In this case, I would try some general recommendations like:
https://www.makeuseof.com/how-to-fix-the-this-app-cant-run-on-your-pc-error-in-windows-10/
Lukas
3,599 次查看
Ahmed_Abd_El-Hafez
Thank you very much Lukas.
Is it a must to flash the MPC5744P by S32DS for the first time only and then I can use RAppID Boot Loader Utility or ?
