S32DS_3.4 _ Command Line compiling
Search instead for
No ratings
IDE: S32 Design Studio Version 3.4
Workspace: C:\Projects\S32DS_3_4
Project name: S32K314_00_blank_00
Project location: C:\Projects\S32DS_3_4\S32K314_00_blank_00
1. After you finish the edit on your codes, please close S32DS
2. Input the command(as below) at your clean_and_build_s32k3_commandLine.bat
3. Run command prompt with Administrator right.
4. Run clean_and_build_s32k3_commandLine.bat at command prompt
You will get the *.elf under the folder of C:\Projects\S32DS_3_4\S32K314_00_blank_00\Debug_FLASH
Cheers!
Oliver
Comments
   If you use RTD to generate your project,  then, you need add all the libraries with option -I, like
   '-I C:\NXP\S32DS_3_4\S32DS\software\SW32K344_RTD_x_x_xx_xxxx\include'
   '-I C:\NXP\S32DS_3_4\S32DS\software\SW32K344_RTD_x_x_xx_xxxx\header'
  Otherwise, error will be happened.
  Hope you will be successful!
Cheers!
Oliver
Version history
Revision #:
1 of 1
Last update:
‎02-25-2021 09:02 PM
Updated by:
