S32 Design Studio for S32 Platform V3.4/V3.5 + SEGGER J-LINK Plus
     This summary records my process of using J-LINK Plus in S32 Design Studio for S32 Platform, hoping to help people who use the same tool.
1.Download the latest package: https://www.segger.com/downloads/jlink/
2.Install the downloaded package and some note will show like this.
3.Open J-Link GDB Server V7.8 , if you current firmware version is too low, you will be prompted to upgrade to the latest firmware version.
At this point ,if you use the default configuration to debug the application, the following error will appear.
Modified the "Debug configurations" for S32 Design Studio platform V3.4
Change the highlighted part to the path below.
C:\Program Files (x86)\SEGGER\JLink\JLinkGDBServerCL.exe
C:\NXP\S32DS.3.4\S32DS\tools\gdb-arm\arm32-eabi\bin\arm-none-eabi-gdb.exe
Modified the "Debug configurations" for S32 Design Studio platform V3.5
Change the highlight part to the path below.
C:\NXP\S32DS.3.5\S32DS\tools\gdb-arm\arm32-eabi\bin\arm-none-eabi-gdb.exe
For now, you may debug your project with SEGGER J-Link Plus Tools.
Hope it works for you!
Comments
Exactly what I needed, all detailed and correct. You saved me hours of frustration.  THANK YOU!
100% helpful (1/1)
Version history
Last update:
‎04-18-2023 08:09 PM
Updated by:
