using SPI0,9s12x
using SPI0,9s12x
1,166 次查看
100asong
CPU is 9s12xep,When we want to use the SPI0,
1.whether we should set the reigister WOMS?What means Pull-push?
2. Whether we should set the priority since that pin :smileytongue:M2/RXCAN1/RXCAN0/MISO0 have 4 function.
Please help me.Thanks.wait on line.
832 次查看
kef
Specialist I
1. http://en.wikipedia.org/wiki/Push%E2%80%93pull_output
To set or not to set WOMS depends on what you are interfacing.
2. You should read MODRR register description.
