void cmd_run(void){
send_nack("first\n");
tcp_send_buffer;
send_nack("EXIT\n");
tcp_send_buffer;
Here is my problem. I can send a tcp data once at each command like this,
void cmd_run(void){
tcp_send_buffer; }
void cmd_run1(void){
tcp_send_buffer; }
Both run and run1 are working fine, however if I try like this
void cmd_run(void){
tcp_send_buffer;
tcp_send_buffer;
It's not working. It freezes after display "first". You guys have any idea? Thanks in advance.
Here is a tcp_send_buffer. It's from the example files.
void tcp_send_buffer(void)
UINT32 len;
while(tcp_checksend(tcp_soch) < 0);
for(len=0;
net_buf[TCP_APP_OFFSET+len] = udp_tcp_buf[len];
if(udp_tcp_buf[len++] == '\n')
break;
if(tcp_send(tcp_soch, &net_buf[TCP_APP_OFFSET], NETWORK_TX_BUFFER_SIZE - TCP_APP_OFFSET, len) == len)
DEBUGOUT("TCP: bytes reply sent!\r\n");
else
DEBUGOUT("TCP: error occured while trying to send data!\r\n");
