mm9z1-638:How to determine if a certain address on the EEPROM has encountered an ECC error?
1,094 次查看
gumu
Dear Sir,
Is there a way to determine if an ECC error has occurred at a specific address on an EEPROM? Since reading an address with an ECC error would result in a machine exception, is it possible to preemptively identify if the address has an ECC fault?
Thanks!
标记 (1)
1,067 次查看
lama
