Dear Sir,
Is there a way to determine if an ECC error has occurred at a specific address on an EEPROM? Since reading an address with an ECC error would result in a machine exception, is it possible to preemptively identify if the address has an ECC fault?
Thanks!
解決済! 解決策の投稿を見る。
I would suggest you to visit....
and probably...
https://community.nxp.com/t5/S12-MagniV-Microcontrollers/ECC-double-bit-error-for-EEPROM/td-p/665878
Ladislav
and probably...
Ladislav
