how to read a word in one clock cycle
yklein
I'm using MC9S12DP256, and in the Freescale manual it says when using PACA (16-bit pulse accumulator) "Full count register access should take place in one clock cycle. A
separate read/write for high byte and low byte will give a different result
than accessing them as a word."
My question is what's the command in C to read the word in one clock cycle?
Lundin
Senior Contributor IV
In your register map, the timer registers should be defined as
volatile unsigned int TC0;
Which will solve the problem.
If you don't have a proper register map, you would have to do something like:
#define TC0 (*(volatile unsigned int*)0x0050)
