how to make ADC configuration with MC9S12ZVC
2,728 次查看
sunkemiao
I have made ADC configuratin according to  soft Demo AN5162 .Now I can use four channels to sample four groups data,but when I want to add a channel to sample data,the MC9S12ZVC do not work under Debugging.You can look at ADC initialization part of my code.
标签 (1)
6 回复数
2,330 次查看
vinitekghare
Where to get AN5162??sunkemiao
2,330 次查看
danielmartynek
I think you are looking for
AN5168 Using the ADC Module in S12ZVM
AN5168SW
2,330 次查看
vinitekghare
Hi Daniel,
Thank you..
Vinit
2,330 次查看
danielmartynek
You should use End_of_list command (CMD_SEL = 0xCx) only for the last channel, after that the measurement will be terminated. Also, make sure the RAM address you use to allocate lists is not address of the stack.
2,330 次查看
sunkemiao
Hi,Daniel:
I follow your advice.I use End_of list command only for the last channel.Now I can sample data. I am very happy,because the problem have perlexed me for long time.
2,330 次查看
sunkemiao
Hi,Daniel :
I have made the
