help on CW4.6 complie error
1,803件の閲覧回数
dynogreen
Hi All,
I have a board with 9S12C and have a return error message after Hiwave loading like below;
Postload command file correctly executed.
Error: unknown identifier
Error: expression expected (use BS ? to query syntax)
Stop at Function: No function with the name "main" was found.
in>
Please help. Many thanks.
3 返答(返信)
488件の閲覧回数
dynogreen
Thanks for the information.
My problem is really on using a existing .abs file to flash the board via the Hiwave.exe and the .abs file is without the debug information, I guess. Can we fix it? Thanks.
488件の閲覧回数
CrasyCat
Specialist III
Hello
Open the file postload.cmd located in your project cmd directory and remove the command
    BS main
CrasyCat
488件の閲覧回数
CrasyCat
Specialist III
Hello
Looking at the message you are displaying I assume that you are building your application without debug information.
Please search for FAQ-27442 on wwww.freescale.com for information on how to make sure you generate debug information for your project.
CrasyCat
