hcs12g128 PAD pins output?
sinanatilla
Can I use PAD pins as output?
iggi
Sure you can.
Just set the bits to logic 1 in the DDR0AD or DDR1AD registers. This will configure the Port AD as output.
Then write desired value to PT0AD or PT1AD registers to get the high/low level signal on Port AD pins.
Detailed info in the S12G ref.manual.:MC9S12GRMV1
iggi
iggi
Sure you can.
iggi
