Why can't my Win7x64 open the EXE file?S12Z_MagniV_Serial_Bootloader_interface.exe
1,093件の閲覧回数
ArchieLuo
Why can't my Win7x64 open "S12Z_MagniV_Serial_Bootloader_interface.exe"?
Can't open S12Z_MagniV_Serial_Bootloader_interface.exe.
Can't open S12Z_MagniV_Serial_Bootloader_interface.jar.
Thanks!
980件の閲覧回数
dianabatrlova
I would like to add the note that we have a newer MagniV Bootloader AN12086. You can look at the below links:
AN12086
https://www.nxp.com/docs/en/application-note/AN12086.pdf
AN12086SW
https://www.nxp.com/docs/en/application-note-software/AN12086SW.ZIP
Diana
980件の閲覧回数
dianabatrlova
I can see in the S12Z_MagniV_Serial_Bootloader_interface folder only file "S12Z_MagniV_Serial_Bootloader_interface.jar"
I assume your issues occur because you should have installed Java x32 version.
Probably you might have selected (C:\Program Files\Java) instead (C:\Program Files (x86)\Java).
For example, my java path C:\Program Files (x86)\Java\jre1.8.0_201 and it works for me.
However, this question is not from my supported area. I'm focused on MCUs rather then java.
I hope it helps.
Diana
