Where can I find the HC12 compiler installation file for CW10.7?
933 次查看
KimSuHwan
I know the CW10.7 version is old, but it's too much to upgrade the version now. So I'm looking for an HC12 compiler upgrade file for the CW10.7 version.
1 回复
911 次查看
lama
Maybe I am wrong but the comment about HC12 and CW leads me to wonder which MCU you are using?
HC12, HCS12  are supported by last version CodeWarrior 5.2.   … Classis
S12Z and MagniV devices are supported by CodeWarrior …. Eclipse
All installation files can be found at (You should be logged in)
https://www.nxp.com/design/design-center/software/development-software/codewarrior-development-tools...
… after selecting the family you can press “See full feature list” in th Suite description you will see download possibilities.
For example..
Ladislav
