Where can I download the program SrecCVT.
2,807 次查看
deeemon8
Hello. Where can I download the program SrecCVT GUI. For some reason, it can not be downloaded from https://www.nxp.com ((
Search Results: sreccvt
2,480 次查看
dianabatrlova
Hi Dmitry,
You are right it cannot be downloaded from this link. It is probably a problem on the NXP website.
SRECCVT software is attached.
However, you can find the SRECCVTSW in the application note for bootloader for S12Z AN12086SW.zip
I hope it helps.
Diana
2,481 次查看
dianabatrlova
Hi Dmitry,
I hope it helps.
Diana
2,478 次查看
deeemon8
Many thanks. You really helped me.
