What is the effect of clearing PCR_SR Register of J638?
1,431件の閲覧回数
528887301
If it is not cleared in my code,  will there be any bad consequences?
1,358件の閲覧回数
dianabatrlova
I have attached Product training for the MM9Z1_638.
PCR_SR (lo) register is used for analyzing the last wake-up source.
To know more about the PCR_SR (lo) flags, please, look at the chapter WAKE-UP SOURCES page 84.
The wake-up flags which need to be cleared after wake-up can be seen there.
PCR_SR (hi) informing you about last reset source page 64. It is not needed to clear it because the reset value is 0. So, only one flag (which causes the reset) will be set.
I hope it helps.
Diana
