What is the Difference between 9s12dg128 and 9s12xdg128 MCU *.s19 code file
752 次查看
Wonder_Mcu
Hi. I want to understand what is the difference MC9s12dg128 and MC9s12xdg128 MCU *.s19 code file. May I use old 9s12dg128 MCU *.s19 code  in place of the new 9s12xdg128 MCU. I do not understand. If you help me I can understand.
Thank you..
标签 (1)
1 回复
491 次查看
kef
Specialist I
Different CPU, different memory map, different peripherals. No, you can't use old S19 on S12X.
