Tool qualification of Codewarrior V11.1 and FreeMaster 3.1
1,627 次查看
magniv-co
We are developing a MCU( S12ZVML) and need to prove tool qualification of Codewarrior v11.1& FreeMASTER3.1.  As I know, there is no certification but I heard that NXP provide customers proven in use documents instead so we try to explain "Increased confidence from use" for qualification. Can I receive the customers proven in use documents?
1,585 次查看
danielmartynek
I sent you CW11.1 Proven In Use document via email.
There is no such document for FreeMaster as this is just a monitoring or debugging tool.
Proven In Use is only required for tools that affect and can change the embedded code or processor.
1,567 次查看
magniv-co
I really appreciate your reply. It was very helpful to me
In case of FreeMASTER, I have to find another method to prove qualification. but it's ok
thank you~ So! much!
1,586 次查看
danielmartynek
