The Time of MC9S12XS128 in debugging and normal area
2,970件の閲覧回数
myonlystar
我使用了微控制器(MC9S12XS128)捕捉脉冲宽度。它曾在调试模式,但同时,结果变得不同,我相信,这是去食堂。因此,它怎么能走呢?
我打开的TIM(TSCR1_TEN = 1)和明确的时间(TCNT = 0)的编号。之后,它才得到的IO(PT0)的TIM的人数(1 = TCNT)为0。
当然,当PT0下降,该TCNT正在清洗(TCNT = 0)。
这就是所有。
但是,当我们在正常模式下,输出是不对的。
我打开的TIM(TSCR1_TEN = 1)和明确的时间(TCNT = 0)的编号。之后,它才得到的IO(PT0)的TIM的人数(1 = TCNT)是0.Of当然,当PT0下降,该TCNT正在清洗(TCNT = 0)。
这就是所有。
1,353件の閲覧回数
kef
Specialist I
Please translate your first post, it's not readable.
TCNT is not writeable in normal modes.
           But how to get the TIME number?
I don't understand this question. Do you mean how to measure something?
unsigned short t0, t1, tdif;
    t0 = TCNT;  // get TCNT before something
    something();
    t1 = TCNT; // get TCNT after something
   tdif = t1 - t0  // difference is TCNT ticks spent in something
3 返答(返信)
1,353件の閲覧回数
myonlystar
ADD:
          TCNT=0xf0;
          PORTB=~TCNTL;
The two sentence goes wrong in normal single module, however they are right in debugging.  I think the TCNT could not be read in normal single module.
1,354件の閲覧回数
kef
Specialist I
    something();
1,353件の閲覧回数
myonlystar
I am a freshman here.
Thank you very much. I have solved the problem.
