TJA1043T UVNOM Flag
TJA1043T UVNOM Flag
zhaojian
HI,NXP colleagues
As 7.2.3 in datasheet mentioned,Setting the Pwon flag clears the UVNOM flag and timers.I want to know if VIO and VCC are always  in undervoltage state,How long will the UVNOM falg be set?
BRS
lama
a wakeup event on pin WAKE or via the bus, a LOW-to-HIGH transition on pin STBN (provided that VIO is present) or a battery reconnection (PWON flag) lead to reset the undervoltage detection flag UVNOM. Thus the transceiver wakes up (INH switched on) along with trying to ramp up VCC and/or VIO again. If there is still an undervoltage condition on VCC and/or VIO, the transceiver is forced into Sleep Mode again after the undervoltage detection time tdet(uv).
Best regrads,
Ladislav
