TIC-S12-XDP512-FLASH-E_W-CW47
TIC example code, v.1.1
* The SW:
* demonstrates FLASH programming as a part of application
* uses adjusted routines from AN2720
* writes a few words into FLASH locations Pages FE and E0~EF may be used for data storage.
  Other pages are used for program storage (see PRM file)
* tested on: HCS12X STARTER KIT
* OSCCLK = 16MHz, BUSCLK = 8MHz
* Reference to documentation: MC9S12XDP512V2 Rev.2.17
Original Attachment has been moved to: XDP512-FLASH-E_W-CW47.ZIP
タグ(1)
評価なし
バージョン履歴
最終更新日:
‎11-29-2013 05:34 AM
更新者:
