Sync field delimiter length. is it possible to generate it with 2Tbits length?
已解决
跳至解决方案
1,848 次查看
piotrreczek
My problem is similar to:
https://community.nxp.com/t5/S12-MagniV-Microcontrollers/Lin-stack-issue-incorrect-sync-delimiter-le...
But that solution did not helped, I mean my delimiter length is still too short after voltage increase.
The best solution would be to make delimiter longer - for example 2-bits.
Is there any  based solution to do that?
I tried with example codes from XGATE - without success.
Thank you for any help.
Piotr
1 解答
1,817 次查看
piotrreczek
Hi Daniel,
Microcontroller is mc9s12zvla128
Stack is the solution from  my company.
Now I have found solution that starts timer after break detection. So i created additional delay to achieve this.
Piotr
在原帖中查看解决方案
2 回复数
1,829 次查看
danielmartynek
Hi Piotr,
Which MCU and Stack version do you use?
Thank you,
BR, Daniel
1,818 次查看
piotrreczek
Hi Daniel,
Piotr
