S912ZVLA and ACLK output.
818 次查看
eifell
Hi guys,
i would like to ask you if anybodey could help me with issue about ACLK output Pin. Ive been searching thru reference manual/datasheet (BTW NXP, its not the same....) and i could not find any mention about pin that should be able to use as ACLK Output. I need to test and measure frequency and stability.
Many thanks for help
Live long and prosper
747 次查看
dianabatrlova
I would like to recommend you to look at the example code how to trim ACLK on S12ZVL MCU Autonomous Clock Trimming SW example for MagniV devices
I hope it helps.
If you have any related questions, please, let me know.
Diana
