S12Z MagniV Serial Bootloader Interface.
1,550 次查看
itsnewforme
I've downloaded the AN5389SW. But, I'm unable to find the S12Z MagniV Serial Bootloader Interface. Please provide the path for this interface.
1,535 次查看
lama
I suppose you have already been able to find following response on these pages
I would like to recommend you to use the newer application note AN12086 - Simple Serial Bootloader for S12Z
https://www.nxp.com/docs/en/application-note/AN12086.pdf
The software of AN12086:
https://www.nxp.com/docs/en/application-note-software/AN12086SW.ZIP
However, the software of the AN4723 can be downloaded here: http://www.nxp.com/files/microcontrollers/doc/app_note/AN4723_SW.zip
Unfortunately the last link does not work so I put the files here. The files are part of the package.
Best regard, Ladislav
1,528 次查看
itsnewforme
Thanks a ton
