S12XD, S12XE - External BUS design - Addendum To AN2708
Search instead for
No ratings
Dear reader,
There is extended information provided in the attached document. it contains detailed description "how-to", example design, detailed memory maps and code examples.
Also tested example projects created under CodeWarrior are attached.
I believe the document as well as SW examples will help you in the design and avoid mistakes we have met under our work in the S12(X) support team.
Yours sincerely,
Ladislav
Version history
Revision #:
1 of 1
Last update:
‎10-09-2012 06:35 AM
Updated by:
