S12G128 Overflow Interrupt Timer
1,463 次查看
rayhall
I have set up TIM with a overflow interrupt. The prescaler is set to precision. I want to set the overflow to exactly 10 msec. The prescaler does not give me a way to set to this time. It also seems that I cannot write to TCNT in the interrupt to control the next overflow time. How can I get the 10 msec I require.
Ray.
1,230 次查看
ZhangJennie
Hi Ray,
attached is processor expert demo code for 10ms overflow interrupt.
in the sample, system clock is 6.25M
interrupt frequency is 6.25M/65536=95.367Hz  that is around 10ms
can this help you?
Zhang Jun
1,231 次查看
ZhangJennie
Hi Ray,
can this help you?
Zhang Jun
1,230 次查看
rayhall
Zhang Jun
Thank you.
Ray.
1,230 次查看
ZhangJennie
Hi Ray,
you are welcome!
Zhang Jun
