S12G vs S12VR SCI baud rate.
Search instead for
fmiku
I using S12G and S12VR series controllers.
Both chips are runing on same OSC setting but the VR series needs much bigger SCIxBAUD values for same baudrate. (about 16 times bigger)
By the datasheets both device's SCI interface are identical.
Where I'm lost ?
Tags (4)
lama
look at the formulas presented below. The tables are taken from datasheets.
....and yes, the diference is 16times
S12VR:
S12G:
Ladislav
