Hey,
i have a problem with the Output Compare function of my MC9S12C64 µC.
When i set the bit for Channel 6 Output Compare in the TIOS register i get the error Illegal_BP when starting the code.
if i use the bean wizard in codewarrior i can generate a pulse but it has double the length i set. If i set pulse width 2730µs then i will measure 5,4µs.
need help plzz
Message Edited by Greeny on 2009-05-20 12:45 PM
