I just want to clone a MC9S12DG256, when a unit is say water damage is to copy info off chip and then flash it back on a replacement unit so the unit does not need configuration (just plug and play).
I would like to do this more reliably then l have been doing without it going bad sometime.
Plus if possible recover the bad flashed units, so they can be re-flashed and then reuse.
What software and hardware do I need to do this (in the best economical way).
Stephen
