I have not worked with the MC9S12XS128, but here is my experience with MC9S12X.
There is good news and bad news.
The bad news is the app note does not apply any more.
The good news is it is easier to do a bootloader from scratch than before.
The app note did a trick of mapping RAM over ROM.
That doesn't work any more: you can't move RAM.
Before, you couldn't move the vector table.
Now, with the VBR, you can move the vector table.
This is better and more standard than mapping the RAM over ROM.
Before there was the crazy trick about making sure you are on an odd byte or something.
That is not necessary any more.
So what you do now is a fairly standard bootloader.
1. You have to execute the bootloader code from RAM.
You can not program ROM while executing from ROM.
So the first trick is to copy your program to RAM
Move the vector table to RAM.
Jump to RAM.
Enable interrupts.
If all this works you are half way home.
2. You need routines to read the serial port and get the data and addresses from the S-records.
3. You might want to preprocess the S-records.
For example, you might want to only use S2 records with global addresses.
You might want to enforce that the S-records contain "phrases" of 8 bytes.
4. You need routines that program the flash.
This is the easy part.
