MM9Z1I638 programmer issue
1,011 次查看
gumu
Contributor V
Dear Sir,
The project was originally using MM9Z1J638BM2EP 128kb flash, and now it has been changed to MM9Z1I638BM2EP 96kb. So I created a new MM9Z1I638 project but found that it cannot be programmed and occour a CRC error. I would like to ask what could be the general problem causing this. Thank you.
974 次查看
danielmartynek
Hello @gumu,
Can you create a new empty project for the I638 part?
Try loading it without any custom code.
If this does not work, please contact PE Micro.
Thank you,
BR, Daniel
949 次查看
gumu
Contributor V
Hi @danielmartynek ,
Yes, it's a new project.
