MIPS of S12ZVMC256
MIPS of S12ZVMC256
Georgio_69
Hello, I tried to get the number of MIPS of the MagniV S12ZVMC256 CPU. Could you please give me this information? Thanks
StanoA
Hello Georgio,
The S12ZVM family core has a 32bit data path to memory, 32bit ALU & MAC, 16bit IO data path, 24bit address; >21 DMIPS.
As you know the final value strongly depends on the used compiler and used instructions so it's hard to say accurate number.
I hope it can help you.
Stano.
Georgio_69
Thanks a lot for the reply. I thought that S12Z core was a 16bits core and it's finally a 32bits core. Only IO data path is a 16bits one. Best regards
