MCU Flasher for MM9z1_638
Boris_Bloxsberg
I want to implement an own software applicantion to flash the MM9z1_638. Could somebody recommand a device to flash this type of MCU and this type of usecase?
Thanks.
danielmartynek
There is no such list.
PEMicro programmers are recommended on each NXP S12Z MCU website though.
S12ZVM:
https://www.nxp.com/products/processors-and-microcontrollers/additional-mpu-mcus-architectures/s12-m...
BR, Daniel
danielmartynek
Hi @Boris_Bloxsberg,
Do you mean a debugger/programmer?
Since the MM9Z1_638 has the S12Z core, you can use those that support S12Z (MagniV).
For example PE Micro Multilink:
https://www.pemicro.com/products/product_viewDetails.cfm?product_id=15320180&productTab=3
Boris_Bloxsberg
Thanks @danielmartynek  for the reply.
Yes, I need a programmer. Is there a list aviable with supported programmers for the S12Z?
danielmartynek
S12ZVM:
BR, Daniel
