Hi all.
I have a problem when I try to program MCU with 4MHz oscillator. It works when the oscillator is not used.
Setup:
CodeWarrior 5.9.0
Vdd: 3.3 V
MCU: MC9S12XEP100-144
External oscillator: http://datasheet.octopart.com/ASV-48.000MHZ-EJ-T-Abracon-datasheet-5458457.pdf (4MHz)
External oscillator output: amplitude is ~ 3.2 V (square wave).
Output of the oscillator has a voltage divider with resistors and capacitor. Oscillator gives ~1.95 V amplitude to EXTAL pin.
XTAL is not connected. VDDpll is bypassed to ground.
Code I'm using to program PLL:
void SetupPLL(void)
// SYNR_SETUP = 0x04 (SYNDIV[1])
SYNR = SYNR_SETUP;
// REFDV_SETUP = 0x04 (REFFRQ[1])
REFDV = REFDV_SETUP;
// POSTDIV_SETUP = 0
POSTDIV = POSTDIV_SETUP;
// wait for the PLL to lock into correct frequency
while(!(CRGFLG & CRGFLG_LOCK_MASK));
// CLKSEL_SETUP = 0x80 (PLLSEL[1])
CLKSEL = CLKSEL_SETUP;
// Check if everything is ok
while(!(CLKSEL & CLKSEL_PLLSEL_MASK));
When oscillator is connected and SetupPLL function is used, the programmer gives verification error @ 0x0000C008.
Also, I have came across with illegal breakpoints and xgate breakpoints. At first I couldn't find the right delay for programming even if automatic delay was used, but when I increased the output voltage from oscillator it started to work. I can use steps until init() functions when it crashes.
When both oscillator and SetupPLL are not used, I can program the MCU without any problems.
I have tried to use signal generator (Vpp 1.8v: 0-1.8 V, 4MHz, same code,) for EXTAL pin, but it didn't work.
If you have any experience about these kind of problems or you could share some ideas how to proceed with this system, I'd be grateful.
-Taavi
VDDPLL max = 1.98V
EXTAL max = VDDPLL + 0.3V ; you have 1.95V => OK
VDDPLL must be connected to GND via C=220nF ; You have written VDDpll is bypassed to ground. => ???
I suppose you have \XCLKS connected to GND (log.0)
In order to calculate PLL setup the easiest way is to use: https://community.freescale.com/docs/DOC-103954
short example for PLL setup:
// The example present PLL setup example
// OSCCLK=16MHz
#include <MC9S12XEP100.h> /* derivative information */
#pragma LINK_INFO DERIVATIVE "mc9s12xep100"
void set_pll(unsigned char _synr, unsigned char _refdv, unsigned char _postdiv);
PLLCTL = 0B00000001; // CME=0,PLLON=0,FM1=0,FM2=0,FSTWKP=0,PRE=0,PCE=0,SCME=1
CLKSEL = 0B00000011; // PLLSEL=0,PSTP=0,PLLWAI=0,RTIWAI=1,COPWAI=1
SYNR = _synr; // Set the multiplier register
REFDV = _refdv; // Set the divider register
POSTDIV = _postdiv; // Set the post divider register
PLLCTL_PLLON = 1; // Enable the Phase Lock Loop
while(!CRGFLG_LOCK); // Wait till the PLL VCO is within tolerance
CLKSEL_PLLSEL = 1; // Select clock source from PLLCLK
ECLKCTL_NECLK=0; // Enable the BusClk output at ECLK pin to see busclk if necessary
void set_plloff(unsigned char _synr, unsigned char _refdv, unsigned char _postdiv)
CLKSEL_PLLSEL = 0; // Select clock source from PLLCLK
void main(void)
//set_pll(0xD8, 0x01, 0x00); // BUSCLK=50MHz from OSCCLK=4MHz
//set_pll(0x05, 0x40, 0x00); // BUSCLK=24MHz from OSCCLK=4MHz
DDRB = 0xFF;
for(;;)
PORTB = ~PORTB;
To check the schematic look into attachment.
Ladislav
