MC9HCS12 Nonvolatile Memory Writing
1,478 次查看
TitoMB345
Hey all,
   I was wondering if anyone knows how to write to nonvolatile memory on the MCU. I'm trying to figure out how to do it for a class project. Basically, I need to be able to save a data when the memory is powered off, but can't seem to find a good guide as to how to set it up. From the advice of my professor, I looked at the code for the Serial Debug Monitor, and saw that it may have some use in solving this problem, but I couldn't quite decipher what I would need to take from it. Does anyone have any helpful hints or advice as to how to achieve this? Thanks!
692 次查看
J2MEJediMaster
Specialist I
Trying searching these forums for the string "Flash programming". Also FAQ-26240 explains some Flash programming basics and points you to a number of useful application notes.
---Tom
