Locking/unlocking car door via relay locking or LIN?
1,047件の閲覧回数
gunsumlut
I was thinking of locking/unlocking a car door by driving the central locking relay via an MCU. Are S12ZVL products better suited for interacting with car door locking/unlocking mechanism ?
Gun
611件の閲覧回数
RadekS
Hi Gun,
Yes, you may use S12ZVL for such job.
However, I would like to recommend also consider S12VR (or potentially MM912G634) MCU.
The S12VR contains 2 low side drivers for direct relay driving (inductive load drivers).
http://www.nxp.com/products/automotive-products/microcontrollers-and-processors/16-bit-s12-magniv/s1...
http://www.nxp.com/products/automotive-products/smart-power-drivers/engine-and-dc-motor-control/powe...
If you don’t need a highly integrated solution, you may also use general purpose MCU like S12G (or some of S08 MCUs) and external analog solution (LDO regulator, LIN PHY, relay driver).
I hope it helps you.
Radek
