List of MagniV and S12(X) Application notes
AN12086 Simple Serial Bootloader for S12Z AN12086 SW
AN5330 Migration Guide for S12ZVM Devices AN5330
AN5327 Three-phase Sensorless Single-Shunt Current-Sensing PMSM Motor Control Application with MagniV MC9S12ZVM AN5327
AN5264 Emulating I2C Master Mode AN5264 SW
AN5207 Hardware Design Guidelines for S12ZVM Microcontrollers AN5207
AN5190 S12ZVM Derivatives Configuring PMF Module AN5190 SW
AN5168 Using the ADC Module in S12ZVM AN5168 SW
AN5135 3-phase Sensorless PMSM Motor Control Kit with MagniV MC9S12ZVM AN5135
AN5122 Using Freescale’s LIN Driver with the MagniV Family AN5122 SW
AN5084 Hardware Design Guidelines for S12ZVL Microcontrollers AN5084
AN5082 MagniV in 24V Applications AN5082
AN4975 Using MSCAN on the MagniV Family AN4975 SW
AN4912 Tuning 3-Phase PMSM Sensorless Control Application Using MCAT Tool AN4912
AN4867 Hardware Design Guide lines for S12ZVC AN4867
AN4852 Using the SENT Transmitter Module in S12ZVC Devices AN4852 SW
AN4842 S12ZVL LIN Enabled RGB LED Lighting Application AN4842 SW
AN4841 S12ZVL LIN Enabled Ultrasonic Distance Measurement AN4841 SW
AN4731 Understanding Injection Current on Freescale Automotive Microcontrollers AN4731
AN4723 S12Z MagniV Bootloader AN4723 SW
AN4722 Real Time Counter (RTC) on the S12ZVH Family AN4722
AN4721 S12ZVH: Hardware Design Guidelines AN4721
AN4718 3-Phase BLDC Hall Sensor Application Using S12ZVM AN4718 SW
AN4704 3-phase Sensorless BLDC Motor Control Kit with the S12 MagniV MC9S12ZVM AN4704
AN4680 PMSM Electrical Parameters Measurement AN4680
AN4643 S12VR - Hardware Design Guidelines AN4643
AN4642 Motor Control Application Tuning (MCAT) Tool for 3-Phase PMSM AN4642
AN4618 Sensorless BLDC Motor Control Using S12G240 Based on HVAC Platform AN4618
AN4617 HMI Design Using HVAC Platform AN4617
AN4616 Flap Motor Control Based On HVAC Platform AN4616
AN4558 3-phase Sensorless BLDC Motor Control Development Kit with MC9S12G128 MCU AN4558 SW
AN4540 Comparison Between the MC9S12VR and MM912_634 AN4540
AN4506 Software Analysis in CodeWarrior for MCU AN4506
AN4505 Safety Considerations S12G-Family AN4505
AN4483 Emulated EEPROM Routines for the S12P Family AN4483 SW
AN4455 MC9S12G128_A240 Demonstration Lab Training AN4455 SW
AN4448 MC9S12VR Family Demonstration Lab Training AN4448 SW
AN4418 MC9S12G64 Demonstration Lab Training AN4418 SW
AN4388 Quad Flat Package (QFP) AN4388
AN4364 Glucose Meter Fundamentals and Design AN4364 SW
AN4320 Introduction to the 16-bit Tower Boards Using the MC9S12GN32 AN4320
AN4303 Light control and diagnostics using a MC9S12GN32 MCU AN4303 SW
AN4302 Introduction to the S12G Family EEPROM AN4302 SW
AN4283 Migrating Software Applications from the S12 (XEXSP) and S08 to S12G Microcontrollers AN4283
AN4268 Three-phase Sensorless BLDC Motor Control Kit with the Qorivva MPC5604P AN4268
AN4263 Modification of the eGUI (D4D) Driver for char Displays (D4CD) AN4263 SW
AN4258 Serial Bootloader for S12(X) Microcontrollers Based on 180 nm Technology AN4258 SW
AN4236 MC9S12XHY-Family Demonstration Lab Training AN4236 SW
AN4143 Migrating from the 16-bit S12XE to 32-bit MPC5604B Family of Microcontrollers AN4143
AN4058 BLDC Motor Control with Hall Effect Sensors Using the 9S08MP AN4058
AN4024 High Speed Stall Detection on the S12HY Family AN4024 SW
AN4021 MC9S12HY-Family Demonstration Lab Training AN4021 SW
AN3961 EEPROM Emulation for the MC9S12XS and MC9S12P Families Using AN2302 as a Reference AN3961 SW
AN3937 MC9S12P-Family Demonstration Lab Training AN3937 SW
AN3936 How to install and run Classic CodeWarrior products on 64-bit Windows 7 PC AN3936
AN3832 Sensorless BLDC Motor Control Using MC9S08AC16 AN3832 SW
AN3784 Understanding the Memory Scheme in the S12(X) Architecture AN3784
AN3743 Emulated EEPROM Quick Start Guide AN3743
AN3624 S12X Temperature Sensor AN3624
AN3622 Comparison of the S12XS CRG Module with S12P CPMU Module AN3622
AN3613 Using the MC9S12XS Family as a Development Platform for MC9S12P Family AN3613
AN3589 Optically-Isolated Multilink BDM Interface for the S08-S12 Microcontrollers AN3589
AN3555 Investigating XGATE Software Errors AN3555
AN3510 S12HZ and S12XHZ Family Compatibility AN3510
AN3497 S12XS Family Compatibility Considerations AN3497
AN3493 TFT display AN3493 SW
AN3490 Overview of the MC9S12XE Emulated EEPROM AN3490
AN3469 S12 and S12XE Family Compatibility AN3469
AN3458 Debugging XGATE Code AN3458
AN3419 System Integrity Techniques for the S12XE AN3419
AN3391 LFAE Bootloader Example and Interface for use with AN2546 (CAN bootloader for S12XE) AN3391
AN3333 Implementing CAN and LIN Signal Level Gateway AN3333 SW
AN3330 Introduction to the Stepper Stall Detector Module AN3330 SW
AN3328 HCS12XD Family Compatibility Considerations AN3328
AN3327 Using the S12XE-Family as a Development Platform for the S12XS-Family AN3327
AN3300 General Soldering Temperature Process Guidelines AN3300
AN3298 Solder Joint Temperature and Package Peak Temperature AN3298
AN3292 XGATE Library SCI Emulation AN3292 SW
AN3291 How to Use IIC Module on M68HC08, HCS08, and HCS12 MCUs AN3291
AN3289 Low-Power Techniques for the S12X Family AN3289
AN3275 S12 All-Access Bootloader for the HCS12 Microcontroller Family AN3275 SW
AN3262 Designing Hardware for the HCS12X D-Family AN3262
AN3257 Meeting IEC 60730 Class B Compliance with the MC9S08AW60 AN3257
AN3253 XGATE Library Load Measurement AN3253 SW
AN3242 S12XD and S12XE Family Compatibility AN3242
AN3226 XGATE Library ATD Average AN3226 SW
AN3225 XGATE Library PWM Driver AN3225 SW
AN3224 Tutorial Introducing the XGATE Module to Consumer and Industrial Application Developers AN3224
AN3219 XGATE Library TN STN LCD Driver AN3219 SW
AN3208 Crystal guide AN3208
AN3153 USB - HID - ZSTAR AN3153 SW
AN3145 XGATE Library Using the Freescale XGATE Software Library AN3145
AN3144 Using XGATE to Implement a Simple Buffered SCI AN3144 SW
AN3034 Using MSCAN on the HCS12 Family AN3034 SW
AN3031 Temperature Sensor for the HCS08 Microcontroller Family AN3031 SW
AN3015 Using the XGATE for Manchester Decoding AN3015 SW
AN2974 Quick Start for Beginners to Drive a Stepper Motor AN2974
AN2881 Mapping Memory Resources on HCS12 Microcontrollers AN2881
AN2880 Using Backdoor Access Capability to Unsecure HCS12 MCUs AN2880 SW
AN2836 Web Server Development with MC9S12NE64 and OpenTCP AN2836 SW SW2 SW3
AN2764 Improving the Transient Immunity Performance of MCU-based Applications AN2764
AN2759 Implementing an Ethernet Interface with the MC9S12NE64 AN2759 SW
AN2734 HCS12X Family Memory Organization AN2734
AN2732 Using XGATE to Implement LIN Communication on HCS12X AN2732
AN2727 Designing Hardware for the HCS12 D-Family AN2727
AN2726 XGATE Library CAN Driver AN2726 SW
AN2724 Using the HCS12X PIT as a 24-bit Elapsed Timer AN2724
AN2720 A Utility for Programming Single FLASH Array HCS12 MCUs, with Minimum RAM Overhead AN2720 SW SW2
AN2708 An Introduction to the External Bus Interface on the HCS12X AN2708
AN2700 Basic Web Server Development with MC9S12NE64 and CMX-MicroNetT TCP-IP Stack AN2700 SW
AN2692 MC9S12NE64 Integrated Ethernet Controller AN2692
AN2685 How to Configure and Use the XGATE on S12X Devices AN2685
AN2678 Using the HCS12 NVM Standard Software Drivers with the Cosmic Compiler AN2678
AN2624 Basic Web Server Development with the CMX-MicroNet TCP-IP Stack AN2624 SW
AN2617 A Software Piority Interrupt Scheme on HCS12 Microcontrollers AN2617 SW
AN2615 HCS12 and S12X Family Compatibility AN2615
AN2612 PWM Generation Using HCS12 Timer Channels AN2612 SW
AN2597 Using the MC9S12E128 to Implement an IrDA Interface AN2597 SW
AN2573 LINkits LIN Evaluation Boards AN2573
AN2554 Clearing and Disabling Interrupt Flags AN2554
AN2552 Configuring the System and Peripheral Clocks in the MC9C12E128 AN2552 SW
AN2548 Serial Monitor Program for HCS12 MCUs AN2548 SW
AN2546 HCS12 Load RAM and Execute Bootloader User Guide AN2546 SW
AN2485 HCS12 Software Stationery AN2485 SW
AN2461 Low Power Management using HCS12 and SBC devices AN2461
AN2438 ADC Definitions and Specifications AN2438
AN2434 Input-Output Pin Drivers on HCS12 Family MCUs AN2434
AN2433 5V to 3V Design Considerations AN2433
AN2429 Interfacing to the HCS12 ATD Module AN2429
AN2428 An Overview of the HCS12 ATD Module AN2428
AN2408 Examples of HCS12 External Bus Design AN2408
AN2400 HCS12 NVM Guidelines AN2400
AN2396 Servo Motor Control Application on a LIN AN2396 SW
AN2342 Opto Isolation Circuits For In Circuit Debugging of 68HC9(S)12 and 68HC908 Microcontrollers AN2342
AN2321 Designing for Board Level Electromagnetic Compatibility AN2321
AN2318 Using the I2C Bus with HCS12 Microcontrollers AN2318 SW
AN2304 Implementation of a UDP-IP (User Datagram Protocol) Stack on HCS12 Microcontrollers AN2304 SW
AN2302 EEPROM Emulation for the MC9S12C32 AN2302 SW
AN2295 Developer's Serial Bootloader for M68HC08 abd HCS08 MCUs AN2295
AN2287 HCS12 External Bus Design AN2287
AN2283 Scalable Controller Area Network (MSCAN) Interrupts AN2283
AN2263 PC Master Software: Creation of Advanced Control Pages AN2263
AN2255 MSCAN Low-Power Applications AN2255
AN2250 Audio Reproduction on HCS12 Microcontrollers AN2250 SW SW2 SW3
AN2221 MI Bus Software Driver for the MC9S12DP256 AN2221 SW
AN2216 MC9S12DP256 Software Development Using Metrowerk's Codewarrior AN2216
AN2213 Using Cosmic Software's M68HC12 Compiler for MC9S12DP256 Software Development AN2213
AN2204 Fast NVM Programming for the MC9S12DP256 AN2204 SW
AN2201 Low Battery Cranking Pulse in Automotive Applications AN2201
AN2189 Using the Clock Generation Module on the HC12 D Family AN2189
AN2153 A Serial Bootloader for reprogramming the MC9S12DP256 FLASH Memory AN2153 SW
AN2104 Using Background Debug Mode for the M68HC12 Family AN2104
AN2103 Local Interconnect Network (LIN) Demonstration AN2103
AN2011 The MSCAN on the MC9S12DP256 compared with the MSCAN on the HC12 family AN2011
AN1954 MPXY8000 Series Tire Pressure Monitoring Sensor AN1954
AN1837 Non-Volatile Memory Technology Overview AN1837
AN1798 CAN Bit Timing Requirements AN1798
AN1783 Determining MCU Oscillator Start-up Parameters AN1783
AN1775 Expanding Digital Input with an AD converter AN1775
AN1771 Precision Sine-Wave Tone Synthesis Using 8-Bit MCUs AN1771
AN1716 Using M68HC12 Indexed Indirect Addressing AN1716
AN1705 Noise Reduction Techniques for Microcontroller-Based Systems AN1705
AN1284 Transporting M68HC11 Code to M68HC12 Devices AN1284
AN1280 Using and Extending D-Bug12 Routines AN1280
AN1263 System Design and Layout Techniques with Single-Chip Microcontrollers AN1263
AN1259 System Design and Layout Techniques for Noise Reduction in MCU-Based Systems AN1259
AN1058 Reducing A_D Errors in Microcontroller Applications AN1058
AN1051 Transmission Line Effects in PCB Applications AN1051
AN1050 Designing for Electromagnetic Compatibility (EMC) with HCMOS Microcontrollers AN1050
AN5389 S12Z MagniV LIN Bootloader AN5389 SW
AN11967 S12ZVM Family in 48 V Applications AN11967
标记 (2)
无评分
版本历史
最后更新:
‎05-22-2023 04:34 AM
更新人:
