Is the IOC0~IOC2 still available on the MM912_S812 ?
616件の閲覧回数
leonlhf
hello,
I know MM912_S812 is a mixture of S12XS and 33812 and some of the pins of S12XS is not included on this MCU.
PT0~PT2 are cut out, but is the output compare and interrupt function still available For I want to use these timer channels.
Thanks!
Lu
タグ(1)
551件の閲覧回数
danielmartynek
Although pins PT0-PT2 are not available on this chip, the S12XS Timer Module is fully functional. So you should be able to use interrupt on output compare match on these channels.
