Is 0x7FFFF8 the reset vector's address?
873 次查看
everkimage
MCU is MC9S12XEQ512,it's about the offical bootloader.
While upgrading,if S Record's load address is 0x7FFFE0,it will write *(u16 *)(&data[24]) into 0x7FEFF8.
This means the content of  0x7FFFE0+24 = 0x7FFFF8 is the app's Reset vector.
But in the MCU datasheet,FFF8 is the interrupt vector of unimplemented op-code trap.I think,the bootloader should write the content of 0x7FFFFA into 0x7FEFF8,cause it's the COP watchdog reset.
Is it right?
788 次查看
everkimage
OK.It's my mistake.
PFlash_Program(u32, u16*) write 8 bytes each time.
So it write dataes at 0x7FFFF8~0x7FFFFF to address 0x7FEFF8~0x7FEFFF.
*(u16 *)(0x7FEFFE) is the application's reset vector,and bootloader get application's entrance from 0xEFFE.
Now it's right.
788 次查看
dianabatrlova
Hello Everk,
Thank you for the information.
I'm glad you solved your issue.
Diana
