I am using CodeWarrior with a MC9S12C32 in a Technologica...
1,383 次查看
bhansen
I am using CodeWarrior with a MC9S12C32 in a Technological Arts NanoCore12 board.  The problem I am having is with a output compare interrupt.
When I run a program from CodeWarrior Debug->(F5) using HCS12_Serial_Monitor the program and interrupt operates correctly on the NanoCore12 board.
When I run the program in the NanoCore12 boards run mode the interrupt routine does not function, but the remaining code does function correctly.  Any suggestions.
708 次查看
JimDon
Senior Contributor III
In what way does it not function properly?
We need more to go on, please explain.
