How to change the memory model settings in an existing project
maxxu
I use s912zvml64 chip to design the driver,With the increase of functions, the code is greater than 16K, and the original setting causes an error
I want to change the memory model from small to medium,How to set codewarrior11? Thank you
StanoA
Hi Maxxu,
The CW_11.1 Special Edition is free and you can build up to 64kB of code:
https://www.nxp.com/docs/en/brochure/BRCWPPI.pdf
You can download it from web:
https://www.nxp.com/design/software/development-software/codewarrior-development-tools/codewarrior-l...
I think it can help you to solve your task.
Stano.
StanoA
Hi Maxxu,
In the CW_11.1 I strongly suggest you to use new project with new memory model.
Just select: File->New->Bareboard Project, put name of project, then select MCU Type ZVML64, and you will reach the page
Then select LARGE memory model and put your routines into this new project.
I think it will help you to solve your task.
Stano.
maxxu
Hi Stano
   thank you,Whether the code warrior11 must have a license. When the code is greater than 16K, because when the memory model is set to medium, the selection page of math and motor control library is missing,If I don't have a license, can I debug more than 16K of code
StanoA
Hi Maxxu,
Stano.
