How to change the BLDC MOTOR rotational direction in S12ZVML-MINIBRD demonstration code?
1,194件の閲覧回数
ShuZ
Hello Mr. or Ms.,
I am now trying to use S12ZVML-MINIBRD to control a water pump, but I don't know how to change the motor rotational direction in demonstration code(S12ZVML-MINIBRD_BLDC_Sensorless_LIN_CW_IDE).
there is a easy way to change the motor rotational direction in physical side, which is change the U/V/W wiring connection, but is there any other solution from software side?
this is my first time in BLDC motor control area.
Thank you very much.
2 返答(返信)
1,177件の閲覧回数
danielmartynek
Hello @ShuZ,
There is no such option, the code supports only one direction.
As you already mentioned, you can switch two phases to change the direction.
BR, Daniel
1,168件の閲覧回数
ShuZ
Understood, Thank you very much!
