How can i read sp of s12zvl 32
ahnjoseph
How can i read a SP of s12zvl32
I need monitor a SP for protection of Stack overflow
MJW
assuming I understand the requirement correctly, the code to read the
current stack-pointer would look similar to this:
/*declaration*/
void *copy_of_stack_ptr;
     /*copy stack pointer*/
     asm {
          ST     S,copy_of_stack_ptr
HTH,
MJW
MJW
/*declaration*/
     asm {
HTH,
MJW
ahnjoseph
Thank you So much !
Now, I can do reading a stack ADDR.
