How can I access the paged RAM variable of MC9S12XEP100
1,725 次查看
兜里揣caca
Hi:
When I store variables in the "paged RAM" area, How should I use it?
for example:
test1 value is wrong, what should i do?
1,528 次查看
lama
I would suggest you to go to
LAMA's S12XE unofficial examples
and search for:
XEP100-RAM-addressing-v1_0-CW51.zip
Of course, I have also attached it here. I only wanted to show you more examples.
Also it is good to absolutely understand memory access possibilities. Attached memory map.
If you want, for example, create large arrays (larger than one page) then access to memory via global memory and global instructions is better.
Ladislav
1,528 次查看
兜里揣caca
Thank you for your reply, and my problem has been solved!
