Hi Xin,
You are right, reference manual do not specify connection of VLINSUP pin.
However we could assume that VLINSUP pin is directly connected into VSUP pin. In fact, I do not see any other option, but I will check it with designers.
I suppose that documentation notes about specification of connection of VLINSUP pin are based on S12ZVM reference manual because there VLINSUP pin connection varies between S12ZVM masksets.
I hope it helps you.
RadekS
