Because I found in datasheet it describe that the Kit must connect with DC power,but I want to test battery,I need the current and voltage to calculate SOC.
I need you help, I will buy this kit within few days,but In China the suppliers only supply kit exclude basic initial software.
Thank you.
Because I do not see any difference between isolated laboratory supply and independent voltage source as 12V battery then the answer is yes if the battery is a power supply.
If you want to measure the battery voltage, then there is pin VSENSE which is designed to connect the battery voltage directly. The kit contains a switch which enables to connect the battery voltage to the MCU.
For more info search for keyword VSENSE in attached datasheet a and user guide for the KIT.
Ladislav
