Fandur wrote:I read the manuals, the reference design code, everything. I just can't make this thing work. All I want is the absolut minimum settings to get a CMD0 out at the 100 pin version. I have been squeezing my brain out trying to make this work, so far unsuccesfully.This are the simptoms:- I configure the SDCLK line as a GPIO and drive it on and off sucessfully. (no short circuit there)- When I turn on the SD module and send a CMD0 i get this clock.
Hello Fandur.
I have some experience working with the 'UF32 and CF cards. I don't know if my experience will cover your problem but if you can give more details on your application and perhaps a pseudo-code snippet of what you're doing I'll look it over.
ron
Hi glork,
Try this out and tell me what do you see at the SDclock pin. I dont think i'm missing any register configuration, if i do please tell me . I'm working with the 100 pin version so i don't need to set the MODRR.
Thank you very much for your time. If you need more information just ask. I'm guessing is some sort of pin redirection problem or something like that.
Message Edited by Fandur on 03-17-200609:17 AM
Message Edited by Fandur on 03-17-200609:18 AM
