HC12XE: how to call _CONV_LOGICAL_TO_GLOBAL asm routine from c++ programming
precisionman
hi,
I want to use _CONV_LOGICAL_TO_GLOBAL asm routine and call it from c++. How do I pass the PPAGE and local address and how to store global address from the routine to a variable?
Thx. Tim
kef
Specialist I
You don't need to call this routine directly. Compiler calls it when required. Try disassembling code below
int * nptr;            // near pointer to int
int * far fptr;        // global pointer to int
int * __rptr rptr;   // RPAGE pointer to int
void main(void) {
  /* put your own code here */
   fptr = nptr;               // _CONV_NEAR_TO_GLOBAL
   fptr = rptr;               // _CONV_LOGICAL_TO_GLOBAL
kef
Specialist I
void main(void) {
