G9S12GN32F0VFT and S9S12GN32F0VFT
1,080 次查看
johnny3
I am wondering what is the exact difference between G9S12GN32F0VFT and S9S12GN32F0VFT?both part numbers can be found on NXP website,and the buy option under G9S12GN32F0VFT shows S9S12GN32F0VFT instead of G9S12GN32F0VFT,this is intresting,anyone can clarify this?thx
1 回复
1,042 次查看
lama
There was a PCN published, I can  not remember number now but....
In past all devices used gold wires for bonding to pins. From some time we have started to use Copper. However, there was still requirement for gold.
The automotive devices with gold are labeled as Gxxxxx and with copper as Sxxxxx. Devices which starts with MC (general devices) are mask independent (if you order you can get any mask available in store) and also bonding is not defined.
Ladislav
