Hi Hong,
Yes, sure. There are several other options.
The range of available solutions is wide and it depends what exactly you need (programming prior/after assembly, programming manual/semi-automatic/automatic, how many programming simultaneous, ..).
Like the CyclonePro may be for example LFBDMPGMR:
The fully automated productions may use professional tools like Lauterbach:
http://www.lauterbach.com/frames.html?home.html
Several other links found by google search (without sorting):
http://www.xeltek.com/isp-programmers/in-system-programmers-superpro-is01/
http://www.smh-tech.com/products/flashrunner-2-0
http://english.rk-system.com.pl/ic_programmers/uprog_icp/
http://www.algocraft.com/en/products/writenow-programmers
https://www.eetools.com/index.cfm/product/791/In-system-Programmer
https://www.elnec.com/en/products/production-programmers/
I hope it helps you.
Radek
Hi Hong,
Radek
Hi Radek,
Thank you for your reply
We are programming in the following way on our assembly line.
- Programming after assembly(SMT).
- Programming manual.
- Programming one by one
if you don't mind, I would like to know your opinion.
Have a good day.
Hi Hong,
from that point of view, the LFBDMPGMR should be enough for such task.
On other side, the CYCLONE_UNIVERSAL or above mentioned programmers will be probably more universal.
Radek
